Warning message
NATTING on PIX's IP ?
Apr 12th, 2002
  • Cisco Employee,
We've been assigned only one IP from our ISP , which has been set on the outside interface.
When I try to use the global command to enable the nat with
global (outside) 1 pix-ip pix-subnet
I get the error message that the NAT overlap the PIX IP.
So how can I enable the NAT with only one IP ?
thanks
ddemers Fri, 04/12/2002 - 03:35
You need to use PAT.
Try global (outside) 1 interface.
Hope that helps.
