Warning message
Troubles with IPSec over FR
Apr 16th, 2002
There are 2610 (c2600-is56i-mz.121-14.bin) & 3661 (c3660-io3s56i-mz.121-14.bin), connected by FR channel. IPSec configured on both side to secure transport layers (TCP & UDP) and at present allow transparent access from LAN behind 3661 to 2610 (tested with telnet, ftp, tftp, rsh, rcp). There is host connected to 2610 on Async 33 by PPP encryption. And traffic from this host incoming to 3610 is NOT encrypted (see log below), although permited in access-list referenced from crypto map. Problem resolved after "no crypto map" && "crypto map ..." on sub-interfaces on both routers. But reload bring that kind of troubles again :(
fragments of running-config on 2610:
crypto isakmp policy 10
authentication rsa-encr
group 2
lifetime 3600
crypto isakmp keepalive 30 10
crypto ipsec security-association lifetime kilobytes 44000000
crypto ipsec transform-set tsCrypt ah-sha-hmac esp-des esp-md5-hmac comp-lzs
mode transport
crypto key pubkey-chain rsa
addressed-key 10.8.27.29 signature
address 10.8.27.29
key-string
x
quit
addressed-key 10.8.27.29 encryption
address 10.8.27.29
key-string
x
quit
crypto map cmCrypt local-address Serial0/0.640
crypto map cmCrypt 10 ipsec-isakmp
set peer 10.8.27.29
set transform-set tsCrypt
set pfs group2
match address aclIntraCrypt
interface Serial0/0.640 point-to-point
ip address 10.8.27.30 255.255.255.252
no arp frame-relay
no cdp enable
frame-relay interface-dlci 640 IETF protocol ip 10.8.27.29
class mc_64-64
crypto map cmCrypt
interface Async33
ip unnumbered Serial0/0.640
encapsulation ppp
no ip route-cache same-interface
no ip mroute-cache
async mode dedicated
peer default ip address 10.8.27.128
no fair-queue
no cdp enable
ppp authentication chap
ip classless
ip route 10.0.0.0 255.0.0.0 Serial0/0.640
ip route 10.0.0.0 255.0.0.0 Null0 254
ip route 10.8.27.128 255.255.255.240 Null0
ip route 172.16.0.0 255.240.0.0 Null0
ip route 192.168.0.0 255.255.0.0 Null0
ip access-list extended aclIntraCrypt
permit udp 10.0.0.0 0.255.255.255 10.0.0.0 0.255.255.255
deny tcp 10.0.0.0 0.255.255.255 eq 22 10.0.0.0 0.255.255.255
deny tcp 10.0.0.0 0.255.255.255 10.0.0.0 0.255.255.255 eq 22
deny tcp 10.0.0.0 0.255.255.255 eq www 10.0.0.0 0.255.255.255
deny tcp 10.0.0.0 0.255.255.255 10.0.0.0 0.255.255.255 eq www
deny tcp 10.0.0.0 0.255.255.255 eq 443 10.0.0.0 0.255.255.255
deny tcp 10.0.0.0 0.255.255.255 10.0.0.0 0.255.255.255 eq 443
permit tcp 10.0.0.0 0.255.255.255 10.0.0.0 0.255.255.255
end
fragments of running-config on 3661:
group 2
lifetime 3600
mode transport
addressed-key 10.8.27.30 signature
address 10.8.27.30
key-string
x
quit
addressed-key 10.8.27.30 encryption
address 10.8.27.30
key-string
x
quit
crypto map cmCrypt_30 local-address Serial1/3.707
crypto map cmCrypt_30 10 ipsec-isakmp
set peer 10.8.27.30
set pfs group2
interface Serial1/3.707 point-to-point
ip address 10.8.27.29 255.255.255.252
no ip mroute-cache
no arp frame-relay
no cdp enable
frame-relay interface-dlci 707 IETF protocol ip 10.8.27.30
class mc_64-64
ip classless
ip route 10.8.27.128 255.255.255.240 Serial1/3.707
end
003130: Apr 16 11:57:56.013: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) dest_addr= 10.8.1.30, src_addr= 10.8.27.128, prot= 6
003165: Apr 16 13:37:40.164: CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) dest_addr= 10.1.12.185, src_addr= 10.8.27.128, prot= 6
I can't understand anymore :(
Please, help with advice.
Thanks.
cjacinto Tue, 04/16/2002 - 16:00
  • Cisco Employee,
On the 2610 ,serial int (FR link that has the crypto map) try turning off fast-switching with:
no ip route-cache
also you mode should be tunnel mode and not transport, as the routers are
actually proxying for the subnets behind it.
begemoth Wed, 04/17/2002 - 01:58
Thank you Cris!
"no ip route-cache" on s0/0 resolve my troubles - I just verify and it works :)
I consider using tunnel mode, but I think fast-switching must remain turned off.
I have not studied the provided configs, so I do not claim to understand the enviroment or the nature of this problem, but I do have something to add.
I use the command 'ip route-cache' in several of my VPN configs. In particular, I have found this command usefull when using policy based routing. The 'ip route-cache' command allows the router to make policy routing decisions without having to process the entire policy for every packet.
The point of my post is that by nature, IPSec VPNs and 'ip route-cache' work fine with each other in some environments. I can not speak for this particular case.
begemoth Fri, 04/19/2002 - 03:13
Do you use "ip route-cache" on main interface of Frame Relay link, one of which subinterfaces participate as IPSec peer?
