errors when uninstall the CD One!
Apr 17th, 2002
I run the /opt/CSCOpx/bin/uninstall.sh, I wanted to uninstall CD One only,but when I choose this option,it says the Campus Manager required it .When i choose the option "uninstall all of the above",it did some operation,but when run to "delete the ciscoworks 2000 packages",the message"ERROR:Get reply from server failed:Connection timed out"appears.
Now the ciscoworks2000 can not work normally,how can I uninstall the ciscoworks 2000 successfully?
rmushtaq Wed, 04/17/2002 - 13:51
  • Blue, 1500 points or more
CD-One is the base foundation for all other applications and cannot be un-installed without removing the applications installed on top of it like RME, Campus etc.
