Warning message
ART/CDR Reporting
Apr 22nd, 2002
CCM 3.1.3a w/ ART installed ,in CCM , CDE & CDRE are both set to TRUE...When I try to pull a report in ART the PDF is blank ....Is there something that I am missing? ...Thanks for any and all help
duc-vu Mon, 04/22/2002 - 14:02
Under Service Parameters, Cisco CM, set Call Diagnostics Enabled and CdrEnabled to True. Also you may give it sometimes to do the report so check back next day or so - if you set up the report for every 24 hours (default).
One thing that I don't know is do we need to run ART on both Pub and Sub when Sub is Primary ? any idea ?
Hope this help.
Duc Vu
j.magee Tue, 04/23/2002 - 05:01
To All: I installed the Art Support Patch the reports all look good....Thanks for the input
