Warning message
How do I check ISP bandwidth ?
Apr 22nd, 2002
I'm using a 2600 router. I don't think I'm getting the expected bandwidth from my ISP's. How can I check the bandwidth of a line during a specified time.
Also, in a FR circuit, how can I check the current CIR?
Any simple math that I can do to find out these values?
With much thanx
vgirnet Tue, 04/23/2002 - 01:45
Only option to test bandwidth is to download something.
Try to download about 5-10 files at the same time, with big size.
The real speed you will see in 5-10 minutes...
If you start to download more files, and the speed decreases on all early downloads, then you got the speed limit.
About CIR - ask the ISP.
TIM KIRBY Thu, 04/25/2002 - 11:41
depending on the LMI type you might be able to see what CIR is configured in their Frame Switch. Use the show frame map command and look for a BW value that is your CIR. Lastly normally you can call a number for your provider and given a cricuit id they can tell you the configured port speed CIR, BC and BE. If you are concerned about the port speed you can alsochec how the CSU/DSU is configred. Look for the number of timeslots it is configured to use.
