04-23-2002 06:10 AM - edited 03-01-2019 09:25 PM
Can anybody explain to me when to configure the different modes for OSPF operation? For example, I have read different stories about configuring in NBMA mode (that this is for ATM, Frame Relay and X.25 as they do not support broadcasts), then you have point-to-multipoint non-broadcast (cannot see the difference). Can anybody explain to me how these modes differ and when to use each one?
best regards,
Daniel,
04-23-2002 06:16 PM
here is what the documentation says :
point-to-point
A point-to-point subinterface has the properties of any physical point-to-
point interface. As far as OSPF is concerned, an adjacency is always
formed over a point-to-point subinterface with no DR or BDR election.
point-to-multipoint
An OSPF point-to-multipoint interface is defined as a numbered point-to-point
interface having one or more neighbors. This concept takes the pre-viously
discussed point-to-point concept one step further. Administra-tors
do not have to worry about having multiple subnets for each point-to-
point link. The cloud is configured as one subnet. This should work
well for people who are migrating into the point-to-point concept with no
change in IP addressing on the cloud. Also, they would not have to worry
about DRs and neighbor statements. OSPF point-to-multipoint works by
exchanging additional link-state updates that contain a number of infor-mation
elements that describe connectivity to the neighboring routers.
non-broadcast
The selection of the DR becomes
an issue because the DR and BDR need to have full physical connectivity
with all routers that exist on the cloud. Also, because of the lack of
broadcast capabilities, the DR and BDR need to have a static list of all
other routers attached to the cloud. This is achieved using the neighbor
command:
neighbor ip-address [priority number] [poll-interval seconds]
where the ip-address and priority are the IP address and the OSPF
priority given to the neighbor. A neighbor with priority 0 is considered
ineligible for DR election.
broadcast
This approach is a workaround for using the neighbor command which
statically lists all existing neighbors. The interface will be logically
set to broadcast and will behave as if the router were connected to a
LAN. DR and BDR election will still be performed so special care should
be taken to assure either a full mesh topology or a static selection of
the DR based on the interface priority.
