Warning message
MCS-7835 Need bigger hard drives!
Apr 23rd, 2002
Are their any supported solutions tfor the Cisco branded DL-380 to move to Compaq 78.2GB drives or something with more disk space for CDRs/CCMbackups/ART , etc.
I would like to delay my disk space worries for several years..
-jason
s.jankowski Mon, 04/29/2002 - 13:15
  • Bronze, 100 points or more
I haven’t heard if they are going to put in bigger drives. You could file a product enhancement request with your sales or tac rep.
dgoodwin Thu, 05/02/2002 - 10:47
  • Cisco Employee,
I haven't heard any plans for this. But you can easily setup the MCS Backup Utility to backup to a network location or a tape drive. The backup does back up the CDR and ART databases.
Also, you can set the CDR and ART databases to purge at certain sizes, and if you want to keep more records than that, you can export the database to a file and move it somewhere else periodically, then merge it into a database on a server with more storage.
