Telnet Response
Apr 26th, 2002
i have a 5505 at a remote site that seems to have a possible problem (though not affecting production). when i log into the 5505, via telnet, the password prompt comes up immediately... then, when i enter the password i don't get the next response for about 30 seconds. also, when i do a "show ip route" i also get a very long delay.
no errors are logging, memory is fine and people are not complaining... just don't understand what's causing the problem.. AND if I telnet to the switch hanging off the 5505 - i have no problems.... thoughts?
paumercier Fri, 04/26/2002 - 10:09
Russell,
I came across the same behavior some time back and found that if dns was setup and enabled the behavior was resolved. Give it a try and let us know.
set ip dns server "your.dns.server.ip" primary
set ip dns server "a.secondary.dns.ip"
set ip dns enable
set ip dns domain "your.domain"
Paul
russell-r Fri, 04/26/2002 - 10:29
Paul,
thanks for the response. I have dns setup and all statements mentioned above are present within the config... strange problem...
