Warning message
network documentation
Apr 27th, 2002
Can anyone suggest a small Windows based Network Documentation software which support network visual view and device (routers, switches, links ... etc) function descriptions.
Muhanna
MickPhelps Sat, 04/27/2002 - 05:56
Not sure what you mean by "small", but Visio is the industry standard. If you wish to exchange layout information with other engineers, visio is what they will be using.
Mick.
jrebellon1 Mon, 04/22/2013 - 19:09
I have a network documentation project(physical and logical). The environment has 100 server, 15 swithces, 15 printers, etc which has 5 racks. My challenge will be trying to following cables, for example, on port 5 of a Cisco switch which is bundled with other cables. Any suggestions for this? Cisco Network Assistant might help. Any suggestions would be greatly appreciated!
Jeff Van Houten Mon, 04/22/2013 - 20:34
  • Silver, 250 points or more
Before physically tracing wires, you might try looking at the switch MAC address tables.
jrebellon1 Tue, 04/23/2013 - 09:08
So spit out the MAC address for each switch/router and match that with MAC address of servers/computers?
Jeff Van Houten Tue, 04/23/2013 - 09:12
Not just each switch, but each switch port. The Mac addresses are specific to a port, so you can tie a server to a specific switchport.
jrebellon1 Tue, 04/23/2013 - 10:47
I will do that. Can you please suggest any Cisco tool/any tool to make this easier?
Collin Clark Wed, 04/24/2013 - 11:06
  • Purple, 4500 points or more
Check out netbrain.
Sent from Cisco Technical Support Android App
jrebellon1 Fri, 05/17/2013 - 13:18
I'm putting together a logical network diagram that includes routers/swtiches and port connection for each port. Any suggestion on how I can do this without for each switch port to ensure it makes sense but not too disorganize?
vmiller Fri, 05/17/2013 - 15:48
  • Gold, 750 points or more
Consider a layered approach.
1. physical. rack row slot/port cable
2. layer 2, vlan spanning treee
3. layer 3 IP relationships.
Ravi Singh Tue, 06/04/2013 - 20:31
  • Cisco Employee,
For network documentation Microsoft Visio and Network Notepad are the best toll. You can work with these.
