Warning message
What software versions support Cat6509 with following configuration?
I would like to know what is the latest IOS or OS version I can/should install on a Cat6509 configured with a Sup1A and a MSFC(1) card. Am I running in 'Native' mode?? This chassis has the the following modules installed:
1000BaseX Supervisor WS-X6K-SUP1A-2GE 6.2(2)
Multilayer Switch Feature WS-F6K-MSFC 12.1(4)E1
1000BaseX Ethernet WS-X6408-GBIC 6.2(2)
10/100BaseTX Ethernet WS-X6248-RJ-45 6.2(2)
Intrusion Detection System WS-X6381-IDS 3.0(3)S13
I will soon be adding a 16-port 1000TX Gig Eth WS-X6316-GE-TX blade as well. I get mixed messages from CCO various sites on what os to load.
THANKS!!
bsivasub Fri, 05/03/2002 - 14:38
You are not running Native IOS. Relese notes lists the min software required for each module.
For now 6.3.6 for sup and 12.1.11bE1 is recommended (personal suggestion ofcourse ;) )
