Warning message
6500 compared to 5500
May 3rd, 2002
Currently I have a Catalyst 5500 with integrated RSM. I am looking to upgrade to a 6500 but am unsure of the terminology of the ruting module on the 6500. Would I require, a Supervisor Engine, plus an MSFC and an MSM? If so, are these ll seperate line cards of contained on the same card. I am also looking to introduce redundant Sups and routing modules, can anyone tell me what slots on a 6513 they take up?
Thanks for your help
Daniel,
The Catalyst 6513 switch chassis has 13 slots. Slot 1 is reserved for the supervisor engine, which provides switching, local and remote management, and multiple gigabit uplink interfaces.
Note The Catalyst 6513 switch requires a Supervisor Engine 2.
Slot 2 can contain an additional Supervisor Engine 2, which can act as a backup if the first supervisor engine fails. If a redundant supervisor engine is not required, slot 2 is available for a switching module.
The Catalyst 6509 switches support the following:
A supervisor engine with two Gigabit Ethernet uplink ports and an optional redundant supervisor engine
Note The uplink ports are fully functional on the redundant supervisor engine in standby mode.
Both supervisor engines in a single chassis must be completely identical. You can configure the redundant supervisor engines in a Catalyst 6000 family switch in one of three configurations:
Two supervisor engines, each with no MSFC and no PFC
Two supervisor engines, each configured with a PFC daughter card
Two supervisor engines, each configured with both an MSFC and a PFC daughter card
The above can apply to a 6509 or 6513. I got this from the below:
Check for full information from
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/6000hw/inst_aug/01over.htm#27539
Cheers
daniel.bowen Fri, 05/03/2002 - 02:48
Where does the MSM come in to play. Is the MSFC an onboard equivalant of the MSM?
Thanks very much for your help
Daniel,
DALE FRANCIS Fri, 05/03/2002 - 02:48
  • Bronze, 100 points or more
Hi Daniel,
The 6500 takes a daugther card on the supervisor module, this is the MSFC. You will not be required to get the MSM and as far as i know they are End of Sale/Life.
So as discussed the MSFC is incorporated on the Sup Module, so you will need one in Slot 1 of any 6500 Chassis. The redundant one would plug into slot 2.
If redundancy is the way you want go with the 6500, i would recommend looking at SRM (Single Router Mode), this will greatly simplify your config process when redundancy is configured. If you did not go SRM, then you would have to config HSRP between the two MSFC's or at least place the redundant one in ROMMON mode.
SRM Redundancy is an alternative to having both Multilayer Switch Feature Cards in a chassis active at the same time. SRM requires MSFC IOS Release 12.1(8a)E2.
Follow this link for some more Info http://www.cisco.com/warp/customer/cc/pd/si/casi/ca6000/tech/hafc6_wp.htm
Dale
daniel.bowen Fri, 05/03/2002 - 03:05
What I was thinking to do, was to use both MSFC's and load balance between the two. Do you not think this is the way to go? Reason behind my thinking, is that on our current Cat5500 with RSM< the RSM has constanlty been overburdened and I wanted to protect against that with dual MSFC's?
Is load balancing possible with the MSFC being located on a REDUNDANT Supervisor, or would the Supervisor need to be active for the MSFC to work?
Thanks very much
Daniel,
DALE FRANCIS Fri, 05/03/2002 - 03:27
Daniel,
Conceptually they are routers on a stick, so yes you would be able to load balance between the two within the same chassis. I assume you would attrack diverse (load balanced) traffic via M-HSRP.
If all things are equal and config registers not changed then you have two routers inside a 6500 chassis.
This might help. :)
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)# interface vlan10
Router(config-if)# standby 10 ip 172.20.100.10
Router(config-if)# standby 10 priority 110
Router(config-if)# standby 10 preempt
Router(config-if)# standby 10 timers 5 15
Router(config-if)# interface vlan21
Router(config-if)# standby 21 ip 192.20.100.21
Router(config-if)# standby 21 priority 109
Router(config-if)# standby 21 preempt
Router(config-if)# standby 21 timers 5 15
Router(config-if)# ^Z
Router# ^C^C^C
Console> (enable) switch console 16
Trying Router-16...
Connected to Router-16.
Type ^C^C^C to switch back...
Router# configure terminal
Router(config-if)# standby 10 priority 109
Router(config-if)# standby 21 priority 110
Router# ^C^C^C
Dale
