Warning message
RPC broadcast on MSFC
May 3rd, 2002
I have a question. I have more then 24 vlans defined in msfc. Most of vlan interfaces have ip helper-address for different server. I’m implementing a NIS broadcast for one vlan by enabling the IP FORWARD PROTOCOL UDP RPC as global command. The problem is now all vlan also allowing the rpc traffic. There is any way to filter or stop just traffic?
bsivasub Fri, 05/03/2002 - 14:51
did you configure extended access-list on the outgoing vlan interface to drop these packets ? worth a try. IP forward protocol is a global command and applicable to all ip helper commands.
mih911@hotmail.com Mon, 05/06/2002 - 07:57
I'm planning to configure extended sccess-list. But, I like to know if there is any other solution and if i have to implement access list with ip directed broadcast there is any URL where I can find the example configuration.
