Warning message
Help me for the router suffered by the Virus.
May 5th, 2002
Experts
One of our client (a Little Service Provider) use a 7204vxr as there
Internet Access Router, they use NAT for their clients, but recently,
the router is always suffered by High CPU Utilization, when they use the
command "show ip nat trans" , a big amount of connection with the same
src & dst ip address are found, maybe caused by RedCode or the Virus
similar, when use "clear ip nat trans *" the CPU Utilization dived down ,
My problem is how to resolve it efficiently?
Thanks in advance
Bryan
waltersm Mon, 05/06/2002 - 03:14
Bryan
The best idea is probably to apply an ACL on the LAN interface refusing traffic using that dst and src - just until you can clean up the infected machine.. This will at least keep it from using up CPU.. Better still: take that machine offline :)
-Matt
crgarcia3 Mon, 05/06/2002 - 05:37
You may want to check the problem against a recent bug release on the 7200 VXR routers:
The link:
Title: Field Notice: Mueslix Halts on Cisco 7200 Series Routers
URL: http://www.cisco.com/warp/customer/770/fn18950.shtml
Posted: April 25, 2002
Summary: On a Cisco 7200 Router, when the mueslix serial port
adapters are used with a high bandwith port adapter (like ATM)
in the same PCI bus, the serial interface may stop functioning
when NVRAM is accessed. This can occur when the interface traffic
rates reach approximately 50 percent on the serial and high
bandwidth interfaces.
Hope the above information will be able to assist you.
C
