Warning message
mimckee Mon, 05/13/2002 - 05:40
  • Cisco Employee,
It depends on the gateway and the telco. If you have an h.323 gateway and you are calling out to the pstn you need to do a progress_ind alert enable 8 on the outbound pots dial-peer you are hitting. If you are doing Pri you need to look at the ISDN messaging to see if you are getting alerting back from the telco. A little more info on your setup would be helpful. Like the type of voice interface and the gateway you are using.
Thank you,
-Mckee
MARTIN IVAN Fri, 05/17/2002 - 01:58
We are using H.323 gateway which is doing PRI. I have changed calling and called numbers at debug isdn q931. I see Alerting is coming but not leaving from the router. And if I type command progress_ind progress enable 8 on
the dial-peer nothing gonna change. Any ideas?
Martin
ISDN Se1/0:15: TX -> SETUP pd = 8 callref = 0x0D50
May 16 13:32:03: Bearer Capability i = 0x8090A3
May 16 13:32:03: Channel ID i = 0xA9839F
May 16 13:32:03: Calling Party Number i = 0x81, '11111111', Plan:ISDN, T
ype:Unknown
May 16 13:32:03: Called Party Number i = 0x80, '22222222', Plan:Unknow
n, Type:Unknown
May 16 13:32:04: ISDN Se1/0:15: RX <- CALL_PROC pd = 8 callref = 0x8D50
May 16 13:32:04: Channel ID i = 0xA9839F
May 16 13:32:10: ISDN Se1/0:15: RX <- ALERTING pd = 8 callref = 0x8D50
May 16 13:32:30: ISDN Se1/0:15: TX -> DISCONNECT pd = 8 callref = 0x0D50
May 16 13:32:30: Cause i = 0x8090 - Normal call clearing
May 16 13:32:30: ISDN Se1/0:15: RX <- RELEASE pd = 8 callref = 0x8D50
May 16 13:32:30: Facility i = 0x91A115020153020122300DA10530030201008201
