Warning message
ATM SNMP traps
I am having trouble getting my 7206 routers to send traps when an ATM pvc changes status. ILMI doesn't work with the Ascend switches that they are connected to, so I'm using OAM-PVC management on the routers. I have snmp traps enabled on the routers with the following line:
snmp-server enable traps atm pvc interval 40 fail-interval 10
Manually toggling a subinterface down on the far end doesn't seem to trigger an alarm even though I see the pvc status change on the near end.
Any suggestions appreciated..
