2950-24 and RADIUS
May 14th, 2002
Do you need to running one of the Intelligent switches in order to be able to use the RADIUS functionality?
I have a 2950-24 here with the latest ios on it and the command does not exsist. The software config guide has a section on setting RADIUS up on the 2950 switches.
bsivasub Tue, 05/14/2002 - 15:56
The latest image is 12.1.9EA1 version and Enhanced image would be best bet for this feature.
anthony.cogswel... Wed, 05/15/2002 - 04:01
Is there a way to force the Enhanced image to be used rather than the standard?
According to the docs the switch chooses the correct image to be installed.
