VPN Client 3.5 and Win 2k DUN
May 14th, 2002
When using the VPN client 3.5 on Win 2k machine, I am not able to access DUN entries using the DUN check button.
It can be made to work by using the third party option. The option is use is: rasdial <DUN entryname> <number> <name> <password>
This works but is not what I want.
Has anyone else had this problem
mmellet Mon, 05/20/2002 - 12:57
You must have Administrator privileges to install the VPN Client on Windows NT, Windows 2000, or Windows XP because these operating systems require Administrator privileges to bind to the existing network drivers or to install new network drivers.
