05-15-2002 12:30 PM - edited 03-08-2019 10:38 PM
How can I change my netrangr password. I have forgotten it but have the root password so I can log into the IDS sensors as root.
05-15-2002 12:43 PM
Login as root and run sysconfig-sensor. Select option 8, Passwords and then option 1, netrangr.
05-15-2002 01:52 PM
On older versions of the software, you will need to type in the username manually when you use sysconfig-sensor option 8.
