Warning message
mcerha Thu, 05/16/2002 - 10:55
  • Bronze, 100 points or more
Network Tools is an application plugin for the web portal system PHP-Nuke. The best way to see if Network Tools is installed is to browse the website causing the alarm. You should see something called Network Tools on the PHP-Nuke portal view. If you find an interface that lets you perform pings and traceroutes, you've got the Netrk Tools plugin installed.
