Warning message
Server load balancing on Local Director implementing HTTP redirection
May 16th, 2002
Hi, got an interesting problem when implementing the HTTP redirection method of session persistance or stickiness when balancing a couple of web servers on a Local Director 416. The session persistance works fine but it looks like one of the two servers is getting all the traffic rather than balancing accross the two. The servers are equally spec'd and when it comes to the predictor setting for the virtual, I'm just using the defaults i.e. leastconns/roundrobin. Is there a better predictor setting to use?? Any input would be appreciated.
Rgds
Adam Lacoba
murabi Thu, 05/23/2002 - 05:59
The “loaded” argument has worked well. Take note that this requires a value to be set with the “weight” command. It gives a specific amount of traffic to one, and then moves to the other.
