Warning message
Browsing network resource
May 20th, 2002
I have a AIR-AP341E2R Access point and AIR-PCM352 series LAn adapter.
All seems ok, the radio signal is at the best, the connection of the base with wired network is ok, from the radio client I can ping all IP's on the wired network but I cannot Browse network resources with the client and I am not able to access internet.
The operating system on my client is win98.
I can see on associations the adsl router wich has been put as a default gateway.
I have also tried to insert the DSN Ip's on wireless base .
Current Version of System Firmware: 11.01
Current Version of Web Pages: 11.01
Current Version of Radio Firmware: 4.13
Can you help me this is my first wireless installation
Tanks
blue.modal Mon, 05/20/2002 - 08:31
1. Check your proxy settings
2. Take a wired client and turn off all protocols except TCP/IP - you may be using a differenet protocol to get to those network resources.
Matthew Wheeler
Blue Modal
