Warning message
Controlling Outbound Caller ID
May 22nd, 2002
I have a situation with CM3.1(2c) where one department wants their DDI numbers given out in the outbound Caller ID, and another department want the CLI withheld.
If I configure the gateway Caller ID DN field with a fixed DN then this fixes it for all both departments.
What combination of gateway and IP Phone - External phone number masks can be configured to achieve the above scenario.
Thanks for any replies
Mike
I asked cisco how to "hide" DN from both internal and PSTN. It sounds the same as what you are trying to do. I found it complicated but it works. So here is cisco's response:
To achieve this we will have to setup a translational table and make
sure that the line which you are trying to hide *always* goes through this
pattern.
Lets say you ahve 2 patterns
phones and xlate
2 CSS'es
phonesCSS and xlateCSS
Then create a translational pattern
the detsination being xxxx (or how many digits you have)
In the calling party transformations , enter the mask.
This translational pattern is in partition xlate and has a CSS of phones i.e
phoneCSS
Now the phone line has a CSS of xlateCSS.
The flow would be,
the call comes into the call manager ..and there is a xlate pattern
associated with it.
It translates accordingly (the calling party number) and then uses its CSS
which is phone CCS
to make the call
msamuels Tue, 06/18/2002 - 03:12
Thanks very much,
Yes this worked, I simply hadn't ticked the translation mask tick box in the route pattern
Thanks again
Mike
dconstantino Tue, 06/18/2002 - 15:43
First go into the RT Pat and check the Use Calling Party's External Phone Number Mask box then put a * in the Calling Party Transform Mask field and this will be global for leaving it blank. If you want it done per user keep the box checked in the RT Pat and remove the *. Then go each phone and put in the mask that you want.
I hope this helps.
