VOIP on VPN
rshanmugam
Hi:
Can somebody do suggest with the version of Cisco soft phone for the IPSEC VPN client? I have tried the same with soft phone version 2.1 and VPN client version 3.5.1, but with no luck.
regds,
Raj
agr
as far as I know there is no proper combination at the moment. If you want to use the softphone in combination with the ipsec client, you have to adjust the ipsec ip address manual in the softphone configuration. Else the wrong ip address would be transfered to the ccm and you will get one way voice.
Greets
AGr
