Warning message
cip to host
May 26th, 2002
My 390 host connected with two cip card,Can I define the virtual mac of two cip as same,So I can implemted load balance. Like this:
interface Channel1/2
lan TokenRing 0
source-bridge 10 1 755
adapter 0 4000.0755.9026
lan TokenRing 1
adapter 1 4000.0755.9026
eligal99 Mon, 05/27/2002 - 01:58
Certainly it is valid to define a duplicate MAC address on 2 separate virtual LAN's. To be on the safe side, I would make the SRB ring-number on the 2nd LAN unique, i.e. change '10' to '11' etc.:
lan TokenRing 1
source-bridge 11 1 755
Obviously you need to define proper CSNA on channel1/0 ans 1/1, and activate the VTAM XCA's pertaining to adapters 0 and 1. All this will let you implemet load balancing...
Eli
