Warning message
Load Balance ?
May 28th, 2002
Hi guys,
I am have a switch cisco WS-C2924C-XL connected to a switch planet FNSW-1600S via 2 fiber optic, in the Fast Ethernet 0/23 I am having :
FastEthernet0/23 is up, line protocol is up
Hardware is Fast Ethernet, address is 0050.806f.2f99 (bia 0050.806f.2f99)
Description: Fibra 4o. Andar
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, rely 255/255, load 4/255
Encapsulation ARPA, loopback not set, keepalive not set
Full-duplex, 100Mb/s
Last input 00:00:54, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 916000 bits/sec, 299 packets/sec
5 minute output rate 1873000 bits/sec, 341 packets/sec
4756463 packets input, 1318032858 bytes, 0 no buffer
Received 17372 broadcasts, 0 runts, 0 giants, 0 throttles
185074 input errors, 25133 CRC, 35781 frame, 0 overrun, 1 ignored, 0 abort
0 watchdog, 520 multicast
6408644 packets output, 2024030263 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 lost carrier, 0 no carrier
In to the Fast ethernet 0/24 I am having :
FastEthernet0/24 is up, line protocol is up
Hardware is Fast Ethernet, address is 0050.806f.2f9a (bia 0050.806f.2f9a)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, rely 255/255, load 1/255
Last input 00:00:00, output 00:00:21, output hang never
5 minute input rate 6000 bits/sec, 6 packets/sec
60306 packets input, 9181191 bytes, 0 no buffer
Received 59664 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 watchdog, 8557 multicast
312 packets output, 50166 bytes, 0 underruns
Like you can see, I am having a lot of traffic into interface Fast Ethernet 0/23 and a lot of CRC and input errors, and into interface Fast Ethernet 0/24 I am having just a little traffic and 0 CRC and 0 input errors, anybody knows like I can solve this problem ?
Alex
thomas.chen Tue, 06/04/2002 - 13:38
  • Silver, 250 points or more
Check duplex and speed settings on the other side of this connections, ensure they match. Swap out ports, and push something new to this port, clear counters, push some data across the port. Your input level is not above acceptable use, just over .1 megabytes a second. Put the other side of the connection under the microscope.
srittenberg Tue, 06/04/2002 - 14:54
Your input error on F0/23 is little high over .02%, and CRC is very high (way over one per million). f0/24 is fine. You need to check on the other end that's connected to f0/23. f0/23 is set for 100/full, and I agree that you need to check the speed and duplex port setup that connected to f0/23 at the other end. if the setup correctly, check the cable. The interface counter has never been cleared, so it's hard to tell about the CRC, when the interface frist come up, it may also create CRC too. The traffic on f0/23 may cause by errors.
