NAT on MSFC
vmiller Tue, 05/28/2002 - 13:12
  • Gold, 750 points or more
the nat config on a pix is altogether different than nat in IOS.
First question, did you order the firewall feature set for the mfsc, I think
you need that first.
MickPhelps Tue, 05/28/2002 - 13:17
If you don't wish for your addresses to be NATed on IOS, just deny them from the access-list you use to define NAT.
ip nat inside source list 1 interface serial0 overload
access-list 1 deny 203.24.1.0 0.0.0.255
access-list 1 permit any
In this case, the network 203.24.1.0 will *not* be NATed, but will be routed. All other addresses will be NATed (PATed) to the IP address on serial 0.
Mick.
