Port Redirection for external web server requests
May 29th, 2002
I have a web server that I'd like to make accessible from outside my network using the public IP on the T1 side of my 2600 router. I'd like all incoming port 80 requests to forward to my web server's private IP. I made the following config changes but I can't access the default page on my server:
access-list 110 deny tcp host 192.168.2.11 any eq www
access-list 110 permit tcp any any eq www
route-map MyWebServer permit 10
match ip address 110
set ip next-hop 192.168.2.11
interface Serial0/0
ip policy route-map MyWebServer
Any help would be greatly appreciated!
John
tepatel Thu, 05/30/2002 - 12:48
  • Cisco Employee,
You can achive the same using just one command..like
ip nat inside source static tcp 80 80
int-ip-web-server = Internal ip address of the web server
public-ip-T1= Public ip address of T1 interface (web server)
Above command will do the following
translates the destination of the IP packets that are traveling outside to inside
translates the source of IP packets that are traveling inside to outside
Pl. visit the later part of the follwing url for more information
http://www.cisco.com/warp/public/556/9.html
