Warning message
output from show csm voice command in 5300
May 30th, 2002
i was curious if anyone could explain the output i received from the show csm voice command in a 5300 that is receiving voip traffic and in turn pushing it to the pstn. from my understanding all dsp's in a voip scenario should have the tdm_chnl = TDM_DSP_STREAM. but i am getting an output that says tdm_chnl=TDM_MODEM_STREAM and then connection_fail_reason=CSM_CAUSE_UNEXPECTED_ON_HOOK. it would appear that the dsp's will show up randomly as TDM_MODEM_STREAM each time you do a show csm voice. is there anyone that has run across this before or does anyone have any suggestions as to what might be wrong. i have another 5300 at a different site setup the same way and it does not have this problem. i am running IOS version 12.2(2)XB5, VCware version 9.19, and DSPware version 3.6.15L. Thanks in advance for any help.
ciscomoderator Thu, 06/06/2002 - 12:05
  • Gold, 750 points or more
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
