Warning message
Schema update error
Jun 3rd, 2002
  • Bronze, 100 points or more
I'm getting a 'C++ runtime' error when trying to run the ADSchemaSetup.exe file. MS Visual C++ Runtime popup box appears right after launching. I'm re-download the files off CCO in case they got hammered during transport. Yes, we are running it on the Schema master w/ schema admin/Ent admin rights. Checked to see if schema was in read-only mode. It's not. Any ideas?<br><br>Are all the files for this update w/in the ADSchemaSetup folder? or are the runtime files somewhere else?<br><br>
kechambe Thu, 06/06/2002 - 00:19
  • Gold, 750 points or more
You need the SelectDisplayLanguage.exe file from the CD-ROM root put the contents of the ADSchemaSetup folder and the Schema folder.
Keith
Keith Chambers
Diagnostic Engineer
Voice Network Team, San Jose
Cisco Systems, Inc.
