Warning message
VPN 3.0 client directly to a 2651 routers bri/dialer interface?
Jun 6th, 2002
Hi, I'm having trouble getting a VPN setup of a 2651 router and the VPN 3.0 client to work. The clients dial into the 2651 and where the crypto map lies on the dialer interface. The client logs in ok and the "tunnel" is up, but no traffic flows. If I use the same setup but uses an second ethernet port in the 2651 as the oputside interface, and connects that to Internet. And then dial the internet with the client, everything i ok. So whats the difference in substituting the ethernet outside with an dialer outside?
ciscomoderator Wed, 06/12/2002 - 12:37
  • Gold, 750 points or more
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
