Warning message
pix 506e to cisco router vpn problem
Jun 11th, 2002
Hello again.
I am trying to set up a pix 506e to router vpn. I have included
the configs. I am establishing an ipsec tunnel but cannot ping a
remote server or map any drives. Cisco has written back saying there
is nothing wrong with my config. The remote cisco pix 506e will
initiate the vpn connection to the main office site. All windows
servers are located at the main office. The handfull of users located
behind the pix need access to shared resources and an exchange server
at the main site. Any suggestions would be greatly appreciated. I
have researched all the posts and contacted cisco but to no avail.
Thank you,
Joe
PIX Version 6.1(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxxxxx encrypted
passwd xxxxxxx encrypted
hostname pixfirewall
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list nonat permit ip 192.168.4.0 255.255.255.0 192.168.1.0
255.255.255.0
access-list ipsec permit ip 192.168.4.0 255.255.255.0 192.168.1.0
255.255.255.0
pager lines 24
interface ethernet0 10baset
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside 216.153.255.76 255.255.255.0
ip address inside 192.168.4.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 216.153.255.77-216.153.255.78
global (outside) 1 216.153.255.79
nat (inside) 0 access-list nonat
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 216.153.255.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323
0:05:00 si
p 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
http server enable
http 192.168.4.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
no floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set pix esp-des esp-md5-hmac
crypto ipsec security-association lifetime seconds 8400
crypto map cisco 10 ipsec-isakmp
crypto map cisco 10 match address ipsec
crypto map cisco 10 set peer x.x.112.209
crypto map cisco 10 set transform-set pix
crypto map cisco interface outside
isakmp enable outside
isakmp key ******** address x.x.112.209 netmask 255.255.255.248
isakmp identity address
isakmp policy 3 authentication pre-share
isakmp policy 3 encryption des
isakmp policy 3 hash md5
isakmp policy 3 group 1
isakmp policy 3 lifetime 86400
telnet timeout 5
ssh timeout 5
terminal width 80
Cryptochecksum:xxxxxxxxxxx: end
[OK]
pixfirewall(config)#
Cisco Router
Building configuration...
Current configuration : 7381 bytes
version 12.2
service timestamps log datetime
service password-encryption
hostname Sheboygan
logging buffered 4096 debugging
enable password 7 0214075007
voice-card 1
ip subnet-zero
no ip domain-lookup
ip inspect max-incomplete high 1100
ip inspect one-minute high 1100
ip inspect name FastEthernet_0_0 tcp
ip inspect name FastEthernet_0_0 udp
ip inspect name FastEthernet_0_0 cuseeme
ip inspect name FastEthernet_0_0 ftp
ip inspect name FastEthernet_0_0 h323
ip inspect name FastEthernet_0_0 rcmd
ip inspect name FastEthernet_0_0 realaudio
ip inspect name FastEthernet_0_0 smtp
ip inspect name FastEthernet_0_0 streamworks
ip inspect name FastEthernet_0_0 vdolive
ip inspect name FastEthernet_0_0 sqlnet
ip inspect name FastEthernet_0_0 tftp
ip audit notify log
ip audit po max-events 100
crypto isakmp policy 3
hash md5
crypto isakmp key xxxxxxxx address 0.0.0.0 0.0.0.0
crypto isakmp client configuration address-pool local VPN_POOL
crypto ipsec transform-set cm-transformset-1 esp-des esp-md5-hmac
crypto dynamic-map mymap 11
set transform-set cm-transformset-1
crypto map cm-cryptomap local-address Serial0/1.1
crypto map cm-cryptomap client configuration address initiate
crypto map cm-cryptomap client configuration address respond
crypto map cm-cryptomap 11 ipsec-isakmp dynamic mymap
isdn voice-call-failure 0
fax interface-type fax-mail
mta receive maximum-recipients 0
controller T1 1/0
framing esf
linecode b8zs
ds0-group 1 timeslots 1-8 type e&m-wink-start
description T1 to Merlin PBX
buffers small permanent 75
buffers small max-free 300
buffers small min-free 50
buffers middle permanent 40
buffers middle max-free 200
buffers middle min-free 20
buffers big max-free 175
buffers big min-free 10
buffers verybig max-free 125
buffers verybig min-free 5
buffers large permanent 6
buffers large max-free 20
buffers large min-free 3
interface Loopback0
ip address 192.168.0.1 255.255.255.0
interface FastEthernet0/0
description connected to EthernetLAN
ip address 192.168.1.200 255.255.255.0
ip access-group 100 in
ip nat inside
ip inspect FastEthernet_0_0 in
no ip route-cache
no ip mroute-cache
ip policy route-map nonat
duplex auto
speed auto
interface Serial0/0
no ip address
encapsulation frame-relay
no ip mroute-cache
frame-relay traffic-shaping
frame-relay lmi-type ansi
interface Serial0/0.1 point-to-point
description connected to CorporateNetwork ARK
ip unnumbered FastEthernet0/0
ip nat inside
no ip mroute-cache
no arp frame-relay
frame-relay interface-dlci x
class voice_ARK
frame-relay ip rtp header-compression passive
interface Serial0/0.2 point-to-point
description connected to CorporateNetwork NJ
ip nat inside
no ip mroute-cache
no arp frame-relay
class voice_NJ
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1
no ip address
no ip route-cache
no ip mroute-cache
hold-queue 300 in
hold-queue 2000 out
interface Serial0/1.1 point-to-point
description connected to Internet
ip address x.x.112.209 255.255.255.248
ip access-group 101 in
ip nat outside
no ip route-cache
no ip mroute-cache
router rip
version 2
passive-interface Serial0/1.1
network 192.168.1.0
network 192.168.2.0
network 192.168.3.0
no auto-summary
ip local pool VPN_POOL 192.168.10.1 192.168.10.254
ip nat inside source route-map tunnel interface Serial0/1.1 overload
ip nat inside source static tcp 192.168.1.3 25 x.x.112.210 25
extendable
ip nat inside source static tcp 192.168.1.3 110 x.x.112.210 110
extendable
ip nat inside source static tcp 192.168.1.250 1494 x.x.112.210 1494
extendabl
e
ip nat inside source static udp 192.168.1.250 1604 x.x.112.210 1604
extendabl
e
ip nat inside source static tcp 192.168.2.250 1494 x.x.112.211 1494
extendabl
e
ip nat inside source static tcp 192.168.3.250 1494 x.x.112.212 1494
extendabl
e
ip nat inside source static udp 192.168.2.250 1604 x.x.112.211 1604
extendabl
e
ip nat inside source static udp 192.168.3.250 1604 x.x.112.212 1604
extendabl
e
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0/1.1
ip route 172.16.0.0 255.255.0.0 Serial0/0.1
ip route 192.168.2.0 255.255.255.0 Serial0/0.1
ip route 192.168.3.0 255.255.255.0 Serial0/0.2
no ip http server
ip pim bidir-enable
map-class frame-relay voice_ARK
no frame-relay adaptive-shaping
frame-relay cir 384000
frame-relay bc 3840
frame-relay be 0
frame-relay mincir 384000
frame-relay fair-queue
frame-relay fragment 480
frame-relay ip rtp priority 16384 16383 90
map-class frame-relay voice_NJ
frame-relay cir 128000
frame-relay bc 1280
frame-relay be 0
frame-relay mincir 128000
frame-relay fragment 160
frame-relay adaptive-shaping becn
frame-relay bc 1000
frame-relay mincir 96000
frame-relay voice bandwidth 90000
frame-relay ip rtp priority 16384 1000 90
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 1 permit 192.168.3.0 0.0.0.255
access-list 10 permit 192.168.0.0 0.0.255.255
access-list 100 permit ip any any
access-list 101 permit tcp any any established
access-list 101 permit udp any eq domain any
access-list 101 permit udp any eq 1604 any
access-list 101 permit tcp any host x.x.112.210 eq smtp
access-list 101 permit tcp any host x.x.112.210 eq pop3
access-list 101 permit esp any host x.x.112.209
access-list 101 permit ip 192.168.10.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 101 permit udp any host x.x.112.209 eq isakmp
access-list 101 permit tcp host x.x.34.13 any eq telnet
access-list 101 permit tcp any host x.x.112.210 eq 1494
access-list 101 permit tcp host x.x.34.14 any eq telnet
access-list 101 permit tcp host x.x.225.213 any eq telnet
access-list 101 permit tcp host x.x.225.212 any eq telnet
access-list 111 permit ip 192.168.1.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 112 deny ip 192.168.0.0 0.0.255.255 192.168.10.0
0.0.0.255
access-list 112 permit ip 192.168.0.0 0.0.255.255 any
route-map tunnel permit 12
match ip address 112
route-map nonat permit 11
match ip address 111
set ip next-hop 192.168.0.2
set ip df 0
snmp-server engineID local 0000000902000002FD61DE80
snmp-server community public RO
call rsvp-sync
voice-port 1/0:1
output attenuation 3
timing wink-wait 160
timing wink-duration 250
description Voice Ports to Merlin PBX
mgcp profile default
dial-peer cor custom
dial-peer voice 3 voip
destination-pattern 4...
session target ipv4:192.168.2.200
ip qos dscp cs5 media
no vad
dial-peer voice 10 pots
destination-pattern 3...
port 1/0:1
prefix 3
dial-peer voice 5 voip
destination-pattern 5...
session target ipv4:192.168.3.200
no vad
line con 0
exec-timeout 0 0
password 7 105C0A1209
login
line aux 0
line vty 0 4
exec-timeout 0 0
password 7 06140C2A40
login
line vty 5 15
login
end
Sheboygan#
Thank You very much,
Joe Sallmann
vijkrish Wed, 06/12/2002 - 03:20
  • Cisco Employee,
As you have a TAC case, I would suggest this issue be worked via the TAC.
Did TAC say they cannot help or don't know what's going on ??
Sincerely,
Vijay
