Warning message
Cisco 506 NAT IPSec
I was wondering if it was possible to have an IPSec tunnel originate within a local area network that sits behind a 506 with NAT'ing enabled. I have tried to use the following command to get this to work to no avail.
sysopt connection permit-ipsec command
The IPSec client that resides behind the firewall requires authentication header and I assume that is where my problem lies. Much thanks in advance.
lisa.hall Tue, 06/18/2002 - 12:59
As long as the client is getting a real NAT address and not a PAT address you should be fine. Does your client software support NAT transparency mode like the one for the Cisco VPN concentrators?
