AP350 - Radio Firmware: 4.25a, how to update ?
Jun 13th, 2002
Hello, i am a bit confused, how i can upgrade the Radiofirmware of an AP350 ? the installed version is 4.25a, I use System Firmware: 11.21.
Where to get the file for the RadioFirmware ?
Why my AP350 shows the following @boottime :
h) FLASH :340 Series FWare 04.25a FE1BB0B4 53608 .tar.gz Data 0000
why he use FWare from the 340 Series ?
thanks
andrew
tepatel Thu, 06/13/2002 - 11:11
  • Cisco Employee,
Actually radio firmware for AP340 and 350 is the same so you may see AP350 using firmware for AP340..Only difference between them is the radio hardware..
Now here is the place which document upgrading procedure for AP340 which is the same for AP350.
http://www.cisco.com/warp/public/102/wlan/ap-fw-upgrade.html
Now here it the place from where you can get the firmware for them
http://www.cisco.com/pcgi-bin/tablebuild.pl/aironet-340
and
http://www.cisco.com/pcgi-bin/tablebuild.pl/aironet-350
Thanks..Tejal
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
