Warning message
jmessina@crimso... Sun, 06/16/2002 - 05:26
You cannot install Personal Assistant on the same system as any other Cisco IP Telephony applications, such as Cisco CallManager, Cisco Interactive Voice Response (IVR), Cisco Auto Attendant, and so on. The installation program will terminate if it detects any of these applications already installed on the system.
marinaibm Sun, 06/16/2002 - 22:20
  • Silver, 250 points or more
Thanks for the response..Do you think i can install it on the same system as Unity? Its just a demo installation and i really dont want to have 3 servers!
thanks
marina
marinaibm Tue, 06/18/2002 - 06:43
thanks John, i will give it a try.Anyway demo installation of the PA isnt supported :)
rbewlay Wed, 06/19/2002 - 01:07
Just to complicate matters - you have to install under a local account - so as Unity is a domain controller, thats probably ruled out... If you have a get around let us know.
