Warning message
ATA 186 Dial plan confusion
yraps Tue, 06/18/2002 - 05:42
Command 310# determine when to detect itr is an IP dail plan.
IPDialPlan: integer value -- allow for detection of ip like destination
# address in dial plan.
# Possible values:
# 1 -- if two '.' is seen, then assume ip being possibly entered.
# 2 -- if three '.' is seen, then assume ip being possibly entered.
# all other values are currently undefined.
# IVR Access Code <310>
Default value --> IPDialPlan: 1
yraps Tue, 06/18/2002 - 10:25
The maximum didgts you can dail is really depend on the terminationg side, could be your Media Gateway which connected to the PSTN.
The ATA186 it self doesn't limit the Max digits you can enter as B#.
Another option could be is the ATA imgae which you have, please verift that is 2.14 or higher.
