Warning message
Nating
Jun 17th, 2002
when do i i use ip nat outside list pool command , what is the difference between the two i.e the inside & outside source-list , is it possible that only the natting for the request of port 80 can be done i.e for the browsing .Can the command be given for the same
aal-buali Mon, 06/17/2002 - 22:06
You can not use ports on NATing but you can with access-lists.
You can use NATing if you have one public IP (outside) that you want to split to a pool of IP addresses (inside).
