Warning message
The Login Local command
Jun 19th, 2002
To ensure security for a remote router telnet function do I use the command “login local” to perform the authentication.
Am I right that the command “login local” is used only with the TACACS or RADIUS implementation? as well as use in the call back function only?
Overall Rating: 5 (1 ratings)
yusuff Wed, 06/19/2002 - 03:23
  • Cisco Employee,
login local means that the user database for authentication is "local on the router" i.e. you crate username/passwords on the router (in config mode using username command)
If you want to authenticate telnet users and your users reside in TACACS/RADISU server then you should do;
aaa authentication login default group tacacs (or radius)
R/Yusuf
wanab Wed, 06/19/2002 - 23:10
Thanks for info. I can’t find the CISCO site regarding the command “login local” and trying to find some explanation to this. It would be great help to point to me the URL link.
I am looking for some explanation on the function, how do I used it, is there any authentication done by the router and how it does it and am not using any of the external TACAS+,RADIUS authentication.
Anyway, I manage to create a login local for remote login but need to understand how it work.
Thanks for help
