To disable this you first need to diable CRC on the line and then disable framing using the cnfln command.
Now If you have an IGX running a version prior to 9.2.40 you will run into bug CSCdu35011 which will not allow you to do this. The fix is to upgrade to 9.2.40 ar later.
Thank You
Manil Uppal
