Warning message
OSPF NSSA
Jun 20th, 2002
  • Purple, 4500 points or more
Here is the scenario...
R1, R2, R3, R4.
R1 is an ABR to area 0. R1 is also attached to area 1.
R2 is an internal router to area 1
R3 is an ABR to area 1 and area 2. Since area 2 is not
attached directly to area 0, area 1 is a transit area,
and there is a virtual link between R1 and R3.
R4 is an internal router to area 2
OSPF has synchornised, all routes are available every
where.
Now area 2 should not get any external route. So area
2 was configured as a stub area. Now the requirement
is, that the ethernet of R4 (x.x.x.x) should be
advertised into OSPF without using network statement.
So I used redistribute command in R4. But since area
2 is a stub area, this is not possible. So inorder to
use redistribute command on R4, area 2 was configured
as NSSA.
R4 gives this route to R3. R3 has this route as ON2.
Now this route should have been converted as type 5
LSA and should appear in R2 and R1. But the route
never appears even in database of R2 and R1.
Looks like, NSSA routes are not converted into Type 5
lsas and exchanged to routers which are in a transit
area.
Please input your valuable comments!
nuno.morais Fri, 06/21/2002 - 02:37
Hello Shanky.
You have to configure "area 2 nssa" in router R3 also.
Hope this helps.
Rgds.
NM
thisisshanky Fri, 06/21/2002 - 09:14
Hi Nuno,
Well...if R3 has the route as ON2 that definitely means that, R3 is configured as NSSA.
The problem i m facing here is, R3 is not sending this lsa into the transit area.
