Warning message
NM-HDV-2T1-48
mimckee Fri, 06/21/2002 - 07:00
  • Cisco Employee,
Yes it does support both. I prefer Pri to t1-cas from a troubleshooting and feature perspective. The pri will be a little more expensive, but it is well wort if. If the customer wants caller id or anything like that pri is a must. This is merely my preference so take it how you will.
Thank you,
-Mckee
Hi Mike,
I still confuse?!?! First of all, I will use NM-HDV-2T1-48 on 3640. And u said that you prefer PRI, I have to agree with you, coz I like PRI better.
However, is this module (NM-HDV-2T1-48) connect either to PBX(in office) or Telco, right?? Well, if connect to PBX, so all PBX support PRI???? If not, I have to use T1 CAS, rite?
If connect to Telco, I just tell them I will use PRI, thats no problem.
Thanks a lot!!
Ken
mimckee Fri, 06/21/2002 - 09:20
  • Cisco Employee,
You are correct it can go to telco or pbx. The PBX will be a lot like ccm in a sense they will have gateways as well. They just call them something different like cards or something. So will be at the mercy of what cards the pbx has as to whether you can do t1-cas or pri. Unless the are buying a new card and you can recommend pri.
Hope this helps explain it more,
-Mckee
