Warning message
E1 config between two 2620 Router
Jun 21st, 2002
hello guy i need your helb
this is my config.
on one site WL19 the controller is alredy up but on the Mue1 down may i check this with telco or is somthing missing on my configuration
Hostname backup_WL19
isdn switch-type primary-net5
controller E1 0/0
channel-group 0 timeslots 1-31
interface FastEthernet0/0
ip address 10.61.254.36 255.255.255.248
speed 100
interface Serial0/0:0
Description Leased Line to Mue1
bandwidth 1984
ip unnumbered fastethernet 0/0
encapsulation ppp
router ospf 1
log-adjacency-changes
area 0.0.0.0 authentication
network 10.61.254.0 0.0.0.255 area 0.0.0.0
no ip http server
conf t
Hostname backup_Mue1
controller E1 1/0
interface FastEthernet1/0
ip address 10.61.254.34 255.255.255.248
speed 100
interface Serial1/0:0
Description Leased Line to WL19
bandwidth 1984
ip unnumbered fastethernet 1/0
encapsulation ppp
router ospf 1
no ip http server
mljohnson Fri, 06/21/2002 - 09:38
If the controller is down, you should have the telco test the line to ensure that it is configured correctly and that their tests succeed. You might also try the different loopback tests available under the controller, to at least verify that a local loopback succeeds and therefore the cable and port are OK.
faheyd Fri, 06/21/2002 - 11:17
On a side note, give your serial interfaces some ip addresses. It sure does help in the troubleshooting process to be able to 'ping' the distant end serial I/F and the ping the eth0, to know where the network is down.
