Warning message
GRE through an ipsec tunnel between a router and a concentrator
Jun 21st, 2002
Can one create a GRE tunnel from an internal router, through a 3005/15 connected to either an ipsec router or hardware client, into another router at a remote site.
Router <---GRE---3005/15 <----IPSEC--->H/W client or IPSEC router ---GRE--->Router
This would allow for dynamic routing updates between central and remote sites. I know it can be done with two routers, but was wondering if the 3005/15 could handle it?
Billy
cjacinto Fri, 06/21/2002 - 20:06
  • Cisco Employee,
You could form a gre tunnel between routers behind a VPN 3000 and a router doing IPSec lan to lan.
