Warning message
UNITY 3.1.4 Static and Distortion
Jun 24th, 2002
We have a CM 3.1.3a SP D and 6608 T1 card with Unity 3.1.4 (just upgraded Fri from 3.1.3 to attempt to solve this problem), and we notice when calling from the outside and listening to Unity prompts, they sometimes sound distorted or robotic and staticy. So far, I haven't had the problem when calling internally.
Any ideas?
kechambe Mon, 06/24/2002 - 16:29
  • Gold, 750 points or more
This is a known issue with the 6608 code. The bug ID is CSCdx36894. It will be fixed with CM 3.1(5). If you can't wait for 3.1(5) you can contact TAC to get a beta load to fix the issue. The beta load you want is D0040301X530.
Keith
