Warning message
Can I Forward Packets to a Linux Firewall?
Jun 24th, 2002
  • Bronze, 100 points or more
Is there a way to forward packets out the Ethernet port<br>
on a Cisco 2600 Series Router through a switch and to a firewall<br>
(Linux box) without physically or logically segmenting the network <br>
so that all traffic has to go through the firewall?
<pre>The router, .1, is on a 24 bit subnet. The Linux firewall has
.2 and .3 for its inside and outside Ethernet ports.
I tried setting a static route to the firewall, but it was
superseded by the directly connected route x.x.x.0/24.
C x.x.x.0 is directly connected to Ethernet0/0.</pre>
<pre>When it forwards the packets out Ethernet0/0, the switch
does its job and forwards the packets to the hosts within
the subnet, skipping the firewall. Is it necessary to
physically segment the network by directly connecting
e0 on the 2600 through a hub to .2 on the firewall?</pre>
Anonymous (not verified) Mon, 06/24/2002 - 14:37
It is not possible to have the interfaces of the firewall
on the same subnet.
