How Do I Configure an Inside (private LAN) Router to Route Through Parallel Firewalls to the Internet?
Jun 24th, 2002
  • Bronze, 100 points or more
Having two default gateways (0.0.0.0) causes the inside router to load balance.
How does the perimeter router (outside) decide which router to send replies
back through? With stateful inspection running, it has to go through the originating
firewall. How do I do this?
Anonymous (not verified) Mon, 06/24/2002 - 14:37
You need to use a Cisco CSS11000 load-balancing switch in front of the firewall.
See the example at:
Configuring Firewall
Load Balancing on the CSS 11000
Also check:
Configuring
Firewall Load Balancing
