ospf summary address and igrp redistribution
Jun 24th, 2002
  • Bronze, 100 points or more
I have the following addresses
10.1.1.65/32
10.1.1.97/27
10.1.1.72/32
10.1.1.69/32
10.1.2.2/30
and have created 2 summary addresses of
10.1.1.0 /24 and 10.1.2.0/24 so that i can redistribute them into an igrp process that is addressed with a 24bit mask.
The summary routes appear when I use show ip ospf summary-address, they do not appear in ospf routing table and are not redistributed into igrp.
Is this because the routes that make up the summary have a longer mask that the summary and therefore not entered into the ospf routing table
Anonymous (not verified) Mon, 06/24/2002 - 14:38
From the IOS 12.0 Network Protocols Command Reference, Part 1, OSPF section concering the
address-summary command:
"For OSPF, this command summarizes only routes from other routing protocols that are being
redistributed into OSPF."
Basically the summary-address command will not summarize OSPF routes. If possible, perhaps you can
create static routes to the 10.1.1.0/24 and 10.1.2.0/24 networks pointing to the null0 interface
and redistribute these static routes into IGRP. Note: if you have additional static routes configured,
you may need to use route maps to control what static routes get distributed into each routing
protocol.
