Warning message
Can I configure VoIP and VoFR( or VoATM) in same router
Jun 24th, 2002
  • Bronze, 100 points or more
Customer used to install VoFR in old network. Now they install new router in new plan , using ppp network. They want to combine VoFR and VoIP.
How to achieve this.
Anonymous (not verified) Mon, 06/24/2002 - 14:38
If your customer want to have both vofr and voip dial-peer
on the same platform. it can be done as long as each dial-peer
is well defined. if the both serve the same destination pattern. simply use
preference to specify which dial-peer is selected for which dial string.
__NOTE88 that voip calls to vofr call is not supported. You either
use voip for end to end, or voip over frame-relay or vofr end to end.
They can co-exist on the same platform, both
can't terminate voip calls and then go out vofr.
