Warning message
Is possible to configure VoIP using Bridge Interface in the router?
Jun 24th, 2002
  • Bronze, 100 points or more
______ Router with FXO ports ________
bridge irb
interface Serial0
mtu 240
no ip address
encapsulation frame-relay
no ip route-cache
no ip mroute-cache
frame-relay lmi-type ansi
bridge-group 1
interface Serial0.1 point-to-point
description connected to Router1
ip address 132.20.0.1 255.255.255.252
no ip route-cache
no ip mroute-cache
interface FastEthernet0
description connected to EthernetLAN
no ip address
no ip route-cache
no ip mroute-cache
speed auto
bridge-group 1
interface BVI1
ip address 10.20.0.1 255.255.0.0
traffic-shape rate 64000000 8000000 8000000 1000
frame-relay interface-dlci 520
frame-relay ip rtp header-compression
bridge-group 1
bridge 1 protocol ieee
bridge 1 route ip
voice-port 1/0
cptone BR
description connected to PSTN (0)
voice-port 1/1
dial-peer voice 1 pots
destination-pattern 300
port 1/0
dial-peer voice 3 voip
destination-pattern 200
session target ipv4:10.20.0.10
ip precedence 5
______ Router with FXS interface _______
bridge irb
interface Serial0
mtu 240
no ip address
no ip route-cache
no ip mroute-cache
bridge-group 1
ip address 132.20.0.2 255.255.255.252
no ip route-cache
no ip mroute-cache
bridge-group 1
description connected to EthernetLAN_1
no ip address
no ip route-cache
no ip mroute-cache
speed auto
bridge-group 1
interface BVI1
ip address 10.20.0.10 255.255.0.0
ip classless
no ip http server
bridge 1 route ip
voice-port 1/0
cptone BR
description connected to Phone (20)
voice-port 1/1
port 1/0
ip precedence 5
How to configure VoIP using Bridge Intarfaces?
Anonymous (not verified) Mon, 06/24/2002 - 14:38
Yes you can, as logn as the ip connectivy is established between source and destintion voip host.
Note: QOS might be a problem in the bridge environemnt..
