IP packet filtering based on MAC addresses
Jun 24th, 2002
  • Bronze, 100 points or more
Can I do IP packet filtering based on MAC addresses when I have IP routing enabled on a cisco router (ethernet)?
I would like to allow certain ethernet host on my network. They all have the same unique OUI. However our network uses IP routing , not bridging. Is there a way to define an access-list based on MAC addresses when I use routing ?
Anonymous (not verified) Mon, 06/24/2002 - 14:38
I dont think so but you could go round this.
Configure the LAN interface for bridging
and apply the MAC access-list to the incoming ethernet
interface. You then enable IRB and creat an interface BVI
which is which would be the point where bridged ethernet traffic
enters the routed network.
e.g
int ethernet 0
bridge-group 1
bridge-group 1 input-address-list 702
interface bvi 1
ip address 1.1.1.1 255.255.255.1 -->an address for the subnets used for host on the LAN
bridge 1 protocol ieee
bridge irb
bridge 1 route ip
access-list 702 permit 0002.4b00.0000 0000.00ff.ffff
Hope it helps
oodunuga
