Warning message
AS5300 and MICA2 modemcode
Jun 24th, 2002
Does AS5300 w/MICA2 modemcard support V.92 and HSCSD (GSM highspeed data)? What is the latest stable IOS for AS5300? I guess S53C-12105T should be ok? Thanks.
tepatel Tue, 06/25/2002 - 08:54
  • Cisco Employee,
If you have mica modems and wants to support V.92, you need to have firmware 2.9.1.0 for mica and ios on AS5300 should be or later then 12.2.(2)XA and 12.2(2)XB. Pl. visit here for more information.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122limit/122x/122xb/122xb_2/ft92mmoh.htm
Any latest XA or XB release is good for V,92 and AS5300..Tejal
pakkanen Wed, 06/26/2002 - 01:37
Thanks for the info. However I'm having problems accessing those newer ISO versions and modem code. I'he never downloaded sw from Cisco, do I need a special access to be able to do that? I guess CCO-guest access isn't enough?
tepatel Wed, 06/26/2002 - 08:26
  • Cisco Employee,
You do need a cco login to download IOS from cco..If you don't have it, try to open a case on www.cisco.com/tac to get the help from cisco's TAC engineers..Tejal
jonaknight Fri, 08/02/2002 - 06:54
What is the Bootloader code that should be used with 12.2.2XB6 and 2.9.2.0? There is only one bootloader code available on CCO that is in the 12.2.X code (12.2.2XA3).
thanks,
makchitale Tue, 06/25/2002 - 09:22
  • Silver, 250 points or more
One more point here, if using 2.9.2.0...to enable v92 will need to have the following modemcap:
&F&D2S54=16840S29=12S21=15S62=8S63=3S34=18000S40=10S10=50
Since 2.9.2.0 (unlike 2.9.1.0) is supported on non-V.92 IOS, Recommended modemcap for 2.9.2.0 for a non-V.92 application:
&F&D2S34=18000S40=10S10=50S54=456
Thanks, Mak.
